Acum este Mie Iun 25, 2025 2:56 pm
 Subiectul mesajului: Help incinta subwoofer 15
MesajScris: Dum Dec 11, 2016 10:08 am
Salutare, detin un difuzor Peavey TNT-1556 si as vrea sa ii fac o incinta pt subwoofer,stiu ca nu e un dif stralucit dar daca il am dc sa nu il folosesc.Mai jos sunt datele necesare pt simulare...
Impedance: 4 Ohms
Power capacity: 900 W Peak, 450 W Program, 225 W Continuous
Sensitivity: 96.7 dB / 1W 1m
Usable frequency range: 40 Hz ~ 3.5 kHz
Cone: Impregnated cellulose
Voice coil diameter: 2.5" (63.5 mm)
Voice coil material: 2 layers, thermally bonded copper wire Kapton former Nomex® stiffener
Net weight: 13.4 lbs. (6.1 kg)
Znom (ohms) 4
Revc (ohms) 3.75
Sd (Square Meters) 0.051
BL (T/M) 12.65
Fo (Hz) 40.6
Vas (liters) 198.8
Cms (uM/N) 193.0
Mms (gm) 79.50
Qms 6.99
Qes 0.480
Qts 0.450
Xmax (mm) 3.2
Le (mH) 0.89
SPL (1W 1m) 96.7
No (%) 2.93%
Vd (cu. in. / ml) 10.0 / 163
Pmax (Watts pgm.) 450
Disp (cu. in. / ml) 192 / 3147
Weight Unpacked: 11.50 lbs (5.216 kg)
Weight Packed: 14.50 lbs (6.577 kg)
Dimensions Packed: 18.25" W x 19" H x 7" D (46.355 x 48.26 x 17.78 cm)
 Subiectul mesajului: Re: Help incinta subwoofer 15
MesajScris: Dum Dec 11, 2016 7:06 pm
http://www.forumpoweraudio.ro/viewtopi ... 92&t=10003
