Acum este Mar Iun 24, 2025 6:14 pm
 Subiectul mesajului: Electro Voice ELX115 Upgrade
MesajScris: Lun Aug 31, 2020 12:23 am
Salutare,se da doua bucati ElectroVoice ELX115 400Wrms
Vreau sa schimb woofer-ele de pe ele,buget 800 lei maxim per bucata
Fara P-audio,sa aiba spl 100db sensitivitate,minim 500-700 watts rms!
DH-1K 39mm (1.5”) Titanium Diaphragm Compression Driver
• EVS-15K 381mm (15”) Woofer
• 50 Hz – 20 kHz frequency range
• 95 dB SPL sensitivity; 134 dB max SPL
• 400 W continuous and 1600 W peak power handling
• Pole-mounts or stacks with Live X Subwoofers
• High Frequency Waveguide with 90° x 50° Coverage Pattern
• 60° Monitor Angle
• 15mm Plywood Enclosure, Internally Braced, with Textured Paint
Mentionez ca pe viitor o sa schimb si Driver-ele, iar filtrul pentru difuzoarele noi o sa ramana aceastea cu care vin ele!
Freq. Response (-3 dB) 75 Hz - 18 kHz¹
Freq. Range (-10 dB) 50 Hz - 20 kHz¹
Axial Sensitivity 95 dB
Crossover Frequency 1.7 kHz
Max. Measured SPL³ 134 dB
Recommended HP Freq. 40 Hz
 Subiectul mesajului: Re: Electro Voice ELX115 Upgrade
MesajScris: Lun Aug 31, 2020 8:22 pm
Asta este recomandarea:
https://www.poweraudio.ro/difuzor_BCspeakers_15NW76?search=15nw
