Acum este Dum Iul 06, 2025 12:39 pm
 Subiectul mesajului: new mid horn design
MesajScris: Dum Mai 14, 2006 4:59 am
Localitate: INDIA
I hv got 12" midbass driver. i want to make horn starting from preferably 240 hz. Upper limit maximum possible.
I will like to hv help from experienced experts here to design, simulate & to guide. I want to use this with T-18, wbin or superscoop for outdoor use.
Nominal Diameter (mm) 306( 12”)
Standard Impedance (Ohm) 8
Power RMS (Watts) 300
Power Program (Watts) 600
Sensitivity 1w/1m (dB) 97
Frequency Range (Hz) 48-5000
Magnet Weight (oz) 90
Voice Coil Material Copper
Former Material Kapton
Voice Coil Diameter (in.) 3
Fs (Hz) 48
Re (Ohm) 6.0
Sd (sqmt) 0.053
Qms 7.28
Qes 0.42
Qts 0.40
Vas (it) 81.02
Mms (gr) 51.88
Bl (T/m) 14.46
Xmax (mm) 3.5
MesajScris: Mar Mai 23, 2006 7:34 pm
Localitate: u.s.a
Wat Will bee your low pass on your woofers and When deciding this i sugest that you place the high pass on your High frequency Driver abought 500-1000 hrtz below the low pass for a seam sess transition :wink:
MesajScris: Mie Mai 24, 2006 9:01 am
Localitate: INDIA
I am planning to use 3 way crossover. For subwoofer low pass crossover will be 300 hz. For midrange planning to start from 240 Hz to maximum possible. Then i will use high pass for compression driver.
there is no suggestion about horn design. Waiting for some beginning so that we can learn/modify the horn.
MesajScris: Joi Iun 08, 2006 2:25 pm
Why do you cross your subs that high? Most subs will sound best if crosst <120 Hz.
With kind regards Johan
Wkr ME
MesajScris: Joi Iun 08, 2006 6:58 pm
Localitate: INDIA
If i cross sub at 120 hz then i hv to cross mid at 120. The horn becomes too big.Let me hv ur views.
MesajScris: Vin Iun 09, 2006 3:25 am
Localitate: u.s.a
well bring the high pass filter on the mids to 100 hz and cross your sub @ 110hz cause u want a little lap over :)
but i do say that u get more sugestions i mean im only 16
