Acum este Mie Iun 25, 2025 1:40 pm
 Subiectul mesajului: AES vs RMS
MesajScris: Mie Noi 04, 2009 7:02 pm
Localitate: Buzau
Diferenta AES vs RMS,astept lamuriri pt. ca eu credeam ca e acelasi lucru dar se pare ca nu ...De exemplu 500 w AES cat e in watzi RMS?
MesajScris: Mie Noi 04, 2009 7:30 pm
difera modul in care se declara puterea pentru ca difera banda de frecventa si tipul de semnal utilizat in procesul de determinare a limitelor termice si mecanice.
da un search pentru ca subiectul a mai fost discutat
ca idee, calculat empiric, 500W AES ar fi cam 400W RMS
MesajScris: Joi Noi 05, 2009 1:33 pm
Localitate: Buzau
ERA VORBA DE UN DIFUZOR CU URMATOARELE SPECIFICATII
Marca nu o spun(nu stiu daca e voie) dar oricum e destul de buna(parerea mea).M-ar interesa daca chiar scoate 400 w RMS?Le-am probat cu o TA2400(T.AMP) CARE AM CUMPARAT-O DE CURAND SI BOXELE(ECHIPATE CU ACEST DIF) vrea sa mi le vanda cineva cu 15 mil.Se merita?Multumesc anticipat.
Nominal Basket Diameter
15" / 380mm
Impedance
8 ohms
AES Power Rating
500 Watts
Program Power 1,000 Watts
Frequency Response
25Hz - 2.0kHz
Sensitivity (1W/1m)
98dB
Voice Coil Diameter
4" / 100mm
Recom. Enclosure Volume 2.12-5.3 ft3 / 60-150 Liters
Voice Coil Length 21 mm
Air Gap Height 9 mm
X Damage (peak to peak) 30 mm
Magnetic Assembly Weight 19.4 lb. / 8.8 kg.
Volume Displaced By Driver 0.25 ft3 / 7 Liters
Overall Depth 5.7" / 145mm
Net Weight 22.49 lb. / 10.2 kg. .
Shipping Weight 24.91 lb. / 11.3 kg.
Materials
Basket Die Cast Aluminum
Cone High Stiffness Paper
Spider Cotton
Metal Parts Anti-Corrosion Coated
Surround Treated Cloth
Voice Coil Copper Round Wire - Apical Former
Magnet High Curie Temperature Ferrite
Thiele-Small Parameters
Resonant Frequency (fs) 27 Hz
Impedance (Re) 5.8 ohms
Coil Inductance (Le) 1.2 mH
Mechanical Q (Qms) 9.01
Electrical Factor(Qes) .26
Total Q (Qts) .25
Comp. Equivelant Vol. (Vas) 12.18 ft3 / 345 Liters
Voice Coil Overhang (Xmax) 7.5 mm
Effective Surface Area (Sd) .088m2
Reference Efficiency 2.5%
Displacement Volume 660 cm3
MesajScris: Joi Noi 05, 2009 2:38 pm
vad ca bobina e de 4"
sunrt aproape sigur ca rezista
Localitate: Mizil Prahova
Da . in mod normal ar trebui sa AIBA , nu sa "scoata" deoarece un difuzor nu scoate Wati ( ala e rolul ampului) ci ii papa.. :roll: .
Daca tu zici ca pe difuzor scrie 500 w AES. atunci va avea 400 rms,.
In general puterea AES este mai mare cu 20% dacat rms.
Deci diful are 400 W RMS, 800 PROGRAM, ( 1600 PEAK. :lol: )
Bafta
Mesaj catre RAI
Trimiteti o ambulanta...
Ingerul pe care mi l-ati dat
Nu face fatza..:))
MesajScris: Sâm Noi 07, 2009 11:03 am
Localitate: Buzau
Thanks Mr Extasy & NEXUS3.M-ati lamurit si am aflat si ceva care era de fapt logic si anume ca dif-ul ''mananca'' Watzii nu ii scoate.Multumesc inca o data. Boxele deja le-am cumparat de la tipul respectiv.Le-am facut si proba la mine acasa. Jaaaale !!! Sarea varul de pe peretzi, mai ales pe testele de subwoofer. Visam sa-mi iau sculele astea de cand eram mic, dar... mai bine mai tarziu decat niciodata.
