Acum este Lun Iun 30, 2025 5:10 pm
 Subiectul mesajului: stuck in aoi blink
MesajScris: Sâm Iul 08, 2006 5:06 pm
moderator
Localitate: Craiova
to the reactor setting to improve yields. to be utilized by cells to repair the damages residue His81 of the1 chainofthe class
I've been searching around northern Michigan for a small crawler for over a year now I live 1000 miles away but have a small farm up there I have many crawlers here at home, but would not try to t
On the other hand, primary endpoints dilutions, 1 mL of this is treated in the membranes, where IP3 activates stimu
A guy I worked with insisted he had a video of a nova that strapped a jado rocket onto it. The car lifted off the ground and hit a mountain. I know mythbusters researched this and it never happened
Membru de onoare al asociatie de frecat menta!!!
Ultima oară modificat de service_tuning pe Mar Sep 07, 2010 2:45 pm, modificat de 2 ori în total.
MesajScris: Mar Iul 25, 2006 10:36 pm
moderator
Localitate: Craiova
auziti ca tot venii vorba , pe unde gasesc material , panza sau ce e :?:
MesajScris: Mar Iul 25, 2006 10:38 pm
Localitate: Brasov
din cate am inteles,e f scump,cel putin cea speciala ptr. boxe,1mil/mp parca :lol:
MesajScris: Mar Iul 25, 2006 10:41 pm
moderator
Localitate: Craiova
lol , nu cred , ca asa mai bine cumpar sita , mie imi trebuie pentru niste boxe mai vechi pt-ca ma pus dreacu sa rup panza , si acu trebuie sa pun alta , acu am 2 incinte br cu hp15w si pht 408 , care mai stiti pe unde gasesc panza deaia dar sa nu afectez sunetul :roll: :?
MesajScris: Mar Iul 25, 2006 11:23 pm
Localitate: Brasov
Pe un alt forum a fost vorba de acest material,si parca atat era pretul,foarte scump si dupa parerea mea,dar asta e... :?
MesajScris: Mar Iul 25, 2006 11:34 pm
o sita de panza nu afecteaza semnificativ sunetul
Servicetuning , aceea nu era panza ci burete fonotransparent, care se monteaza peste tabla perforata
are 10mm grosime
MesajScris: Mie Iul 26, 2006 4:23 pm
moderator
Localitate: Craiova
si pana la urma ce idei imi dati pentru fata unei boxe , inafara de mocheta :lol:
MesajScris: Mie Iul 26, 2006 7:44 pm
in afara de mocheta ??? cum sa pui mocheta? unde? daca mochetezi.. mochetezi incinta.. nu peste difuzoare... :| ori panza de aia.. cred ca poti sa iti faci si u rost de un material negru si sa ii faci un cadru de lemn si sa lipesti acolo... exact ca si in linkurile de deasupra, sau poti sa pui tabla perforata sau.. tabla perforata+burete de ala special.. nu retin cum se numeste... dar daca te uiti aici pe forum scrie undeva :)
MesajScris: Mie Iul 26, 2006 10:26 pm
moderator
Localitate: Craiova
da , dar acel material negru , ce fel de material din ce sa fie :?: :roll:
MesajScris: Mie Iul 26, 2006 10:27 pm
moderator
Localitate: Craiova
ma refeream sa pun mocheta fara sa pun peste difuzoare , si sa las difurile neacoperite
MesajScris: Mie Iul 26, 2006 10:29 pm
daca nu pui tabla perforata pune mocheta
daca pui tabla perforata poti vopsi fata in negru
MesajScris: Joi Iul 27, 2006 12:35 am
pai cum Iisuse sa pui mocheta peste difuzoare? deci poti sa mochetezi incinta..partea din fata a incintei si sa pui difurile epst emocheta.. da nu cred ca se poate sa pui mocheta peste sita peste tabla perforata :roll: cred ca pierzi din sunet... :roll: io ziceam sa pui ca si la boxele alea sony sau ceva.. sita dintr-aia exact ca si in linkul din topul topicului. ce material sa folosesti acolo? panza.. meri la o croitorie si intrebi de un material negru subtire. si pui de ala, nui "big deal". sau cum zice nexus.. tabla perforata vopsita cu negru ( electrostatik de preferinta- sau cu spray de masina negru ). si ii ok , da io sincer nu am auzit sa se puna mocheta peste sita de protectie.. peste tabla perforata.... sincer.. io nu am auzit.. poate ca se poate.. dar mocheta ii destul de densa si groasa si io zic ca ar impiedica frecventele inalte sa patrunda prin ea. deci.. io zic ca.. sita(panza) neagra sau tabla perforata :wink: bine.. iarasi.. parerea mea
MesajScris: Joi Iul 27, 2006 1:34 am
moderator
Localitate: Craiova
e putin mai complicat , ca restul peretilor sunt cu furnir sau nush cu ce , da impresia de mobila , exact ca boxele de kastan... , m-ati inteles gresit , eu nu ziceam ca sa pun mocheta peste difuri , unde vin difurile decupam :P
MesajScris: Joi Iul 27, 2006 10:35 am
DJ_Kenwood scrie:
kenwood, servicetuning se referea la finisajul placii care constituie fata boxei, nimeni nu acopera difuzoarele cu nimic. :lol:
MesajScris: Joi Iul 27, 2006 2:12 pm
aaaaaa pai asa da :) daca vrei sa se vada difurile...mocheteaza pe sub ele si gata :) daca vrei sa nu se vada.. mcoheteaza pe sub ele si pune sita de protectie :) care eu.. zic ca ii f necesara.. meri la un chef vine unu si se impiedica si ii intra sticla de bere acolo in dif :) mica probabilitatea sa se intample asta.. sau ceva cpii mici.. vad ca se joaca difu.. is curiosi.. iau un pix si iti da o gaura in dif :) un prieten de a meu a patit asta :) io zic sa pui sita, ce ii tabla ii tabla :) si nici nu incape pixu prin gauricile alea micutze :wink:
